TractorLinks.com
Re: 19.5 HP Briggs burning oil
joe csuti
05-27-2014 16:46:35
Do a leakdown test on eng BEFORE pulling head,this will give you a better idea of what problem is & what you're getting into,if it's a leaking head gasket it's a fairly simple straight forward in place job replacing gasket,if rings are the problem you're talking removing eng from tractor & a complete teardown of same.In addition you should take block to a machine shop & have cyl bore measured for wear as block may need to be bored & throwing a std set of rings in eng may not cure your problem if ring wear is involved.
It is also HIGHLY recommened that you get a service/repair for your mod# eng as you WILL need same for head bolt tighting sequence,torque setting for head bolts & valve clearance in addition to any other info you need about eng.
OH Boy
05-28-2014 18:55:40
 Re: 19.5 HP Briggs burning oil in reply to joe csuti, 05-27-2014 16:46:35
Yeah I was thinking I need to get a service manual for it too if I am going to tear it down. Thanks for your input.
