410 Alis Chalmers Garden Tractor
Garry J W
New User
Hi
Could anyone tell me where I could get a new carb for the 10 hp kohler thats in my Alis.Maybe other parts for this tractor also
Thank You
Garry
Call these numbers on Tuesday. You will need the engine model & spec numbers. Should be on the fan shroud. Hal
1-650-645-4700 CA
1-763-413-1344 MN
It's a k241 kohler I'd check ebay or type it in on google, I have a 410 and its by far my favorite garden tractor, does your have a shuttle shift or the three speed
Hi
Thank you all for your responses and info.
Its a 3 speed.
I will check out all your leads on Tuesday.
Also what kind of price is a carb for this 10 hp Kohler ?
Get the mod/spec# off eng then click on link below,lookup your mod/spec# in kohler eng parts listings to get correct pn carb,after that do a google search for kohler+pn and shop around for prices,also do same search on ebay to check prices for oem carb or a possible aftermarket carb that replaces orig kohler pn.
kohler
It'll be around 200 I'd guess, why do you need a complete carb is it missing? If its still there more than likely you can rebuild it for under $20
I got a Carb for a K241 Kohler from NAPA Auto
Parts ! They are listed in NAPA's "Outdoor
Power Equipment Replacement Parts" catalog.
Hi
The main reasion I want a new carb is when it comes to rebulding one I am hopeless.
This one works good but the shaft that comes up through the top of the carb which has the governor connected to it is so loose it keeps moveing around. Don"t know if I can get a bushing for that or even if it can be fixed
I haven"t asked my neighbor if he can rebulid this one But thats a idea,He did replace the piston and rings not long ago in it But hate to bother him again.
In 2007 in Minnesota I got flooded and the Alis was comepleatly under water so I changed the gas and oil and tried it It started up easy lol,Course the fuel pump went soon after that but if it started after going through that. I think it deserves to get some good care now
Kohler makes a throttle shaft repair kit for k241 carb,goto ebay & search kohler 25-757-15-S,oem & aftermarket kits listed,also try a google search for same.
Thank everyone that replyed to my post.
I found a new carb on ebay for 53 dollars with free shipping.and a new muffler to.
You Guys are great
Thank you all again
Garry
