I have a starting problem. When you turn the ignition switch to the start position nothing happens. You can start the engine by running a jumper cable from the battery to the starter. Works fine.
I have changed out the ignition switch and solenoid. I have also shorted or direct wired the safety switches. It"s a puzzler.
Could you run a cable from the battery to the starter with a starter switch (on/off) in between?
Ideas will be appreciated.
JB9959
JB9959
