Cub cadet 100 governor linkage
Pmer
I picked up a model 100 with a deck and push blade. It is having a couple issues. The RPMs go past high idle and governor doesn't seem to work when load comes on. Does anyone have a picture or a PDF of the throttle linkage and spring connections?
It is leaking some oil out of the front of the creeper assembly too.
Click on link below & download/save service manual for K series eng,starting on pg 6.31 of manual are instructions for setting up & adjusting governor.
kohler
That download help a lot. The high idle stop was not used and the spring to governor arm was in the wrong spot too. Also repositioned the throttle cable housing and now its acting a lot better. Thanks.
