jeffcat
Yup it is like three holes up and three holes down. The spring is straight across. That PDF file will fix you up. One of my "K" engines was so bad I welded the top hole shut and re drilled it correct size. Works fine now. The carb shaft was another story. The carbs on these must be set correctly so that the engines will not hunt. Take your time and read everything! Good book!!
