FLOLDFORD
- Location
- Lakeland Florida
Got this 1960 German Holder A12 from a friend of mine back in February. The Sachs 2 stroke diesel was completely worn out. Did get it to run but had very low compression and a very noisy bottom end. After many weeks of searching the internet I discovered that parts for this engine are just about nonexistent her in the US. So I decided to swap it out for a 14hp Kohler that I had in the shop. As you can see by the photos it took a little bit of redneck engineering but I made it work. I made all the parts here in my shop with a torch, welder, drill press, lathe and a small milling machine. I have run it quite a bit this weekend and so far it seems to work fine. Little tractor has live hydraulics, three point, and 6 speeds forward and 3 reverse. But 6 gear is a lot faster than I want to drive it. I know a lot of you will say that I should have stayed with the Sachs motor but I haven't done any thing that would keep me from putting it back in if I ever find the parts or the time to rebuild it. Only cost about a $100 in parts to make the swap and I saved another old piece of iron. Maybe a little modified but saved non the less
