I changed the engine from a magneto ignition to a battery ignition. No more intermitten spark. Runs perfect, all the time. The only thing is, there is no charging system so the battery will have to be recharged occasionally. I installed a 2 position key switch to be used to shut it off so the points won't stay hot and burn up. Used a kohler coil with internal resistor.
Thanks to everyone for the suggestions. It sure helps to come to the website for help.
PS. The original post is way down on page 5. This project got put on the back burner for a while.
Thanks again, Sam
Thanks again, Sam
