TractorLinks.com
Re: Leaking carb
t.r.k.
05-02-2014 19:18:56
Like the others have said, your leak may be a damaged o-ring on the mixture screw. There should be a washer between it and the spring, so the spring will not damage the o-ring.
The smallest o-ring in some universal o-ring kits will probably work, if you can't find one any other way. It als is (or was) in the largest carburetor kit that Tecumseh made, but I forget the part number.
tater_51
05-03-2014 10:28:12
 Re: Leaking carb in reply to t.r.k., 05-02-2014 19:18:56
Think I may have solved it. Removed the screw/spring and found that the O-ring was basically gone, little pieces. Local hardware had bin full of O-rings, found the smallest one there and it seems to have stopped the leak. Thanks for all the information and help!!
