Hi Guys,
I just bought an old troy built horse rototiller with the old Tecumseh engine on it (30 years old?). The wheel seals are leaking on the tiller and the gear oil is low so I'm going change it before using the tiller. I'm getting conflicting information. The manual seems to indicate that all I have to do is set the tines on the ground and fill it from the handle bar hole and it should fill the transmission case and the tiller gear case both from the one source. However, I read online that they are actually two separate reservoirs. Can anyone confirm which way it actually is?
Thanks,
Stephan
Thanks,
Stephan
