gravely 8123 clutch hub removal reply
rdrunr
New User
New to this forum, how do i reply, i dont find a send button, so started from the beginning.
Ray, its the inner hub that goes in the transmission case, the part you showed me comes off in a assembly with the 2 nuts
Never had THAT offa there....should just slide off the splined shaft, there's a snap ring that it rides against behind it. The spring inside the bore of the clutch disc assembly keeps it tight against that snap ring behind it (and the two pieces of clutch seperated) Should pull off of there.
