Yesterday's Tractor Co.
Shop Now View Cart
Re: 444 Case Hyd. pump
Tom Arnold
04-25-2014 15:01:27
I need the serial number off the ID plate on the dash.
Pump squeal is not unusual. Before he condemns the pump, he should crawl underneath and chase the two steel lines that go to the rear PTO valve. Look to see if they are touching one another or touching the tractor.
If so, then get some short lengths of heater hose and slit them lengthwise. Slide these short lengths over the steel lines and position them where the lines are contacting other parts. Zip Tie them tightly into place and then Zip to the line to something solid.
In order to determine if the pump is actually bad, he needs a 5000 PSI glycerin filled pressure gauge along with some high pressure hose and fittings. No point tossing a good pump if all that's wrong is pump noise being amplified.
04-25-2014 17:13:30
 Re: 444 Case Hyd. pump in reply to Tom Arnold, 04-25-2014 15:01:27
Now, that is interesting!
I had not considered that.
I think I'll have to try that on mine and see if it quiets down my drive motor noise.
Thanks for the info Tom!
