Yesterday's Tractor Co.
Shop Now View Cart
Re: kohler sv530,17 hp oil switch
joe csuti
04-24-2014 04:49:46
Then do as the lite says,check eng oil level.
If oil level not low check owners manual,depending on make/type of equipment eng on same may have an eng monitoring system that is factory set & monitors eng hrs between oil/filter changes & has to be reset after each oil/filter change,in addition to indicating low oil pressure lite may also turn on as a reminder for eng maint.required.
Other possible causes of lite on ,plugged/restricted oil filter or oil cooler,stuck/bad oil pressure sw,worn oil pump,internal wear/problem in eng causeing loss of oil pressure or a problem in wiring harness on equipment.
05-09-2014 15:42:31
 Re: kohler sv530,17 hp oil switch in reply to joe csuti, 04-24-2014 04:49:46
hi joe ,thanks for the info,I did just that,there is no sentry switch,and I cant find anywhere to reset dash LED,it flashes voltage # of hours and CHG OIL,I removed battery lead to see if it will reset?
05-17-2014 10:36:42
 Re: kohler sv530,17 hp oil switch in reply to steve5150, 05-09-2014 15:42:31
hi guys,I found the fix for my kohler engine,you keep the key on for 5-20 minutes and it will reset the LED,I am told this will happen every 50 hrs,to change oil,Thanx to all.
