Re: John Deere 112 HELP???
joe csuti
04-24-2014 04:12:53
Many of the 112 tractors have a fuse in wiring harness between battery terminal on starter sol & ammeter on dash check that fuse not blown,after that check that cable connections for battery are clean/tight at battery,battery terminal at starter sol & where neg(-)of battery cable connects to eng block/tractor frame,also check that small red wire that connects to sol battery terminal not loose/broken,after that check for loose/broken connections at ammeter & ign sw,beyond that you'll need a wiring diagram of tractor as problem may be other loose/bad connections or in wiring harness itself.
