Yesterday's Tractor Co. New Parts for Old Tractors
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
ATV, Kawasaki
murray2
04-23-2014 18:16:04
142.167.147.53
Hi , this is probably not the proper place to be asking this question. Someone might suggest another forum. I have a Kawasaki, Bayou 220 that must have a dead short some where's in the wiring and I cannot locate. When connecting the battery after connecting the postive wire, then hooking up the ground, it instantly blow's the 20 Amp fuse, replaced the selenoid, checked all the wiring. Asking for suggestions, what to do next. Thanks, Murray
[Reply]   [No Email]
shinnery
04-23-2014 23:55:25
216.189.193.51
 Re: ATV, Kawasaki in reply to murray2, 04-23-2014 18:16:04
Another thing you can do to save on fuses is to replace the fuse with a 12V light (bulb). When the light is bright you still have a problem and when the light is dim the problem may be fixed. It will not draw enough current to blow the light.
Bryce
[Reply]  [No Email]
Steve@Advance
04-23-2014 21:17:09
107.203.134.67
There is no simple answer to finding a short. A wiring diagram would be helpful. That would give you an idea what is on that circuit and the direction the circuit goes. Then you can start disconnecting each component until the short goes away and be inspecting the harness as you go.
Being it's an ATV, good chance it is a burned or crushed wiring harness. Look underneath, any area that would be subject to damage from road debris. Look around the exhaust system for melted wiring. Check pivot points around the steering, suspension, storage compartment lids, etc. There are a lot of wires in the handle bars. Look where the wire harness goes into the handle bars, look where the accessories attach to the bars, has something been hit, come loose and twisted cutting the wires?
Here's a hint, steady poking fuses in is going to get expensive. Make a jumper wire to TEMPORARILY bypass the fuse but DO NOT LEAVE IT CONNECTED! You're only going to TOUCH it across the fuse and watch for a spark. As you go through the shorted circuit disconnecting components, touch the jumper across the fuse and see if it sparks. If it still sparks, it's still shorted. But be careful! If the jumper wire gets hot, your leaving it connected too long!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
