TractorLinks.com
Re: Poulan Chain Saw
El Toro
04-23-2014 04:21:00
I have a Sears saw made by Poulan that's over 30 years old. Never had any starting problems until I used gasoline containing alcohol. It ruin the gas lines. On your saw pull the sparkplug after it quits running. Reconnect the plug wire to the plug then see if there's any fire to your plug when cranking. Your coil/armature may be weak when the saw gets hot. Hal
That old?
04-23-2014 06:29:16
 Re: Poulan Chain Saw in reply to El Toro, 04-23-2014 04:21:00
Are you sure it wasn't because the fuel lines on a cheap chainsaw were 30 years old?
T in NE
05-04-2014 11:35:59
 Re: Poulan Chain Saw in reply to That old?, 04-23-2014 06:29:16
30 years ago Poulan made a good saw. Some of their models were carry-overs from the Pioneer line. Had a saw that was half Pioneer farmsaw and half Poulan.
El Toro
04-23-2014 12:36:18
Never had a problem until gas contained alcohol. Dealers now tell you to drain the tank after being used. It ruins the neophrene parts in the carburetor. What makes you think it was cheap. Sears doesn't give anything away. It still cuts good. Hal
HCooke
04-26-2014 16:32:32
 Re: Poulan Chain Saw in reply to El Toro, 04-23-2014 12:36:18
Also, Poulan saws 30 years ago were better than they are now.
ShadetreeRet
04-23-2014 21:30:22
Hal is right. The Sears chain saws built by Poulan were some of the best little saws ever! Fuel lines were never really a problem. I wore two of them slap out, have one now and enough parts to build another, and most of the repair parts are NLA.
