Yesterday's Tractor Co.
Shop Now View Cart
Re: deere 318 onan b series
04-22-2014 13:57:35
spark will jump a 3/4 inch gap w/ bright blue spark...switched plugs from side to side,no change...seems to be a fuel issue...if I flood it out for a sec both cylinders will fire for about a minute,then back to missing.
thanks for all the responses...
Roger in Iowa
04-22-2014 14:37:22
 Re: deere 318 onan b series in reply to dbrojr, 04-22-2014 13:57:35
Sounds like you have an intake manifold air leak causing left hand cylinder to run very lean.
Spray some starting fluid around left hand intake manifold when running to see if it finds the leak inward. Be careful!
04-23-2014 20:37:12
 Re: deere 318 onan b series in reply to Roger in Iowa, 04-22-2014 14:37:22
Second the vacuum leak.
04-24-2014 05:16:37
 Re: deere 318 onan b series in reply to Steve@Advance, 04-23-2014 20:37:12
removed intake and found a stripped bolt...fixed bolt and resealed leaks change....checked carb as well.
