Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 25 HP Kohler
Butch(OH)
04-17-2014 05:02:49
Check the voltage at the big terminal (not the wire) on the starter to the battery ground POST (again, not the wire) while trying to crank it. Weak connections can give voltage readings but loose then when load is applied and that sounds to me like what you have. if it drops to 0 under an applied load take your jumper cables or a heavy jumper wire and run it from the battery ground terminal to the starter case and try it. If still nothing try same from positive to the starter.
