TractorLinks.com
Re: kohler k241
joe csuti
04-16-2014 17:52:55
One other thing you could check & it probably won't be fun,if this welder has seen hard use,check crank bearings same may be worn/sloppy & depending on eng speed & load on eng crank may be shifting changeing flywheel/coil air gap,also check crank end play,with speed/load magnets in flywheel may be moving out of line with coil legs.Check flywheel magnets,if there are tracks across magnets from coil legs this is usually a sign of worn crank bearings.
