Yesterday's Tractor Co. Trusted Parts Supplier since 1995
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
25 HP Kohler
jf
04-16-2014 15:28:52
173.16.229.117
I"m chasing gremlins I think! Went to start it and it turned over about 1/2 a turn and stopped like it blew a fuse. I checked the fuse and it checks ok, then checked the safety switches, they ok. Bench tested the starter-no life so, new starter. Put it on - still nothing. Have 12 V to the starter, but only .75 V to the switch wire at the starter. Jumped across the terminals at the starter, nothing-or a small spark but wont turn over. I have enough power to start the hour meter and the electric clutch most times but it got me stumped. Checked the grounds and they seem ok. I know its something simple, but I cannot find it. Any one found a trick to what I"m doing wrong?
[Reply]   [No Email]
jf
04-18-2014 21:01:39
173.16.229.117
 Re: 25 HP Kohler in reply to jf, 04-16-2014 15:28:52
Thanks all - I will check those out.
[Reply]  [No Email]
greygoat
04-17-2014 07:24:38
98.125.120.185
Take the spark plug out. See if it turns over.
It could be hydro-locked, with gas. My Snapper
rear engine rider, 11 HP Briggs, has the float
sticking open. It often locks up like that when
it sits. I finally put a gas shut off valve in
the line, easier than taking the carb apart.
Yes ! I still forget to shut the gas off some-
times !
[Reply]  [No Email]
Butch(OH)
04-17-2014 05:02:49
66.192.33.38
Check the voltage at the big terminal (not the wire) on the starter to the battery ground POST (again, not the wire) while trying to crank it. Weak connections can give voltage readings but loose then when load is applied and that sounds to me like what you have. if it drops to 0 under an applied load take your jumper cables or a heavy jumper wire and run it from the battery ground terminal to the starter case and try it. If still nothing try same from positive to the starter.
[Reply]  [No Email]
El Toro
04-17-2014 04:06:10
96.244.7.206
There may not be anything wrong with your old starter. I use a full size car battery Group 75 from Walmart in my garden tractor. Hal
[Reply]  [No Email]
joe csuti
04-16-2014 17:13:38
72.251.74.191
If all battery cable connections clean/tight at both ends the more that likely cause is a weak/bad battery,check battery with a hydrometer or remove & have load checked.
IF you have a voltmeter/12v test light connect across battery,try to start tractor,if battery voltage less that 11v or light gets dim/goes out the battery needs a charge or replacement.
[Reply]  [No Email]
El Toro
04-16-2014 17:04:11
96.244.7.206
Measure the battery voltage while cranking to see how far it drops. You can use an hydrometer and measure the specific gravity in each battery cell and record the readings. 1.280 on a fully charged battery. The readings should be close to one another. Hal
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
