TractorLinks.com
Re: kohler k241
ACSam
04-16-2014 05:47:28
Thanks for the replies and suggestions. I did have the metal plate off to clean and so I could get the new high tension lead and point wire in behind it. I was very careful putting it back, no pinching. I am running with the point cover off. New spark plug. It is the ignition module under the flywheel, not a battery ignition engine. What little wiring there is is all new oem. I did use a screw driver on the magnets and it felt ok. Keep in mind, it is doing the exact same thing it was doing from the beginning. I am lost on this one.
Thanks to everyone for the help. Any other ideas are welcomed.
Thanks, Sam
joe csuti
04-16-2014 17:52:55
 Re: kohler k241 in reply to ACSam, 04-16-2014 05:47:28
One other thing you could check & it probably won't be fun,if this welder has seen hard use,check crank bearings same may be worn/sloppy & depending on eng speed & load on eng crank may be shifting changeing flywheel/coil air gap,also check crank end play,with speed/load magnets in flywheel may be moving out of line with coil legs.Check flywheel magnets,if there are tracks across magnets from coil legs this is usually a sign of worn crank bearings.
