Troy built tiller axle removal
Bdd
New User
Working on a 70 s horse for a friend. I can't get the wheel off the left side so I read you could drive the axle out. Pulled the right seal removed the snap ring, shims, and bushing. Tapped on the axle and nothing. What am I missing? Thanks for any help.
I never took an axle out of one, but I think you should take the top off the transmission and see if a snap ring or two or a roll pin or something is holding the gear on the shaft.
