Yesterday's Tractor Co.
Shop Now View Cart
Re: What motor?
04-14-2014 10:20:14
Hi G1355, 120 psi is good, as Joe posted it could be a lean setting of the idle circuit, turn the idle jet out about 1/4 turn and see if it starts and runs better if you make it too rich it will smoke black when the throttle is advanced, those are good old engines lots of power and torque and they do like gas. If you want a manual for the engine look for: B&S Repairman's Handbook for Older Engines 1919-1981 CE8069, it should be available on the web somewhere, it covers many engines and at first is a little hard to figure out but all the information is there.
The owner operators manual is available from B&S on there site, you'll need all the numbers off the blower housing Model type and code numbers.
GB in MN
04-14-2014 12:36:24
 Re: What motor? in reply to MNGB, 04-14-2014 10:20:14
Ok, I don't ever work on Briggs motors, I have a hh100 and k241 which I know very good, and know how to set carb, but the Briggs is kinda different. I will mess with the setting on the carb.
El Toro
04-19-2014 11:22:04
 Re: What motor? in reply to G1355, 04-14-2014 12:36:24
Your carburetor may be similar to the one on my Toro Grassking mower. You may need to open that main jet adjusting screw. If they're too lean the engine may overheat and lack power when working the tractor hard. Hal
