JD400 steering problem
Anonymous-0
Hi, i have a 400 thats hard to turn, the pump wines alot turning , fluid is full, is my steering valve bad? the other owner must have hit something cus i had to straighten out parts let me know what you guys think thanks.
Have you changed the hydro filter?
Could be a failed piston seal in the steering cylinder or a damaged (in the draglink) steering valve, or even binding in the linkage or front spindles.
Bent P/S cylinder? Jack it up and start taking things loose till you find the thing that is binding, and hope it is not the valve.
