Yesterday's Tractor Co. Same-Day Parts Shipping Available
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
JD 400
Dennis (VA)
04-14-2014 06:33:55
70.208.161.6
I have a JD 400 that was running fine until I tried to start it yesterday after it set for few days. The engine started but wouldn't smooth out buy manipulating the throttle and choke, It stopped and I tried to restart. The started sounded like it was grinding and didn't seem to really turning over the engine. Next try nothing. Next try more grinding but it seemed like the engine or something was causing resistance or stuck. How can I determine what happened. Apparently,to even assess the starter the engine must the un-bolted from the frame and raised.
Really dread having to go to JD Dealer without taking out a bank loan.
[Reply]   [No Email]
rrobert
04-14-2014 09:40:24
107.5.202.31
 Re: JD 400 in reply to Dennis (VA), 04-14-2014 06:33:55
I think the "crosses" refers to the U joints between engine and driveshaft. It is probably a piece of rubber that allows flexing between engine and shaft.
I would turn the engine backwards first. The starter gear might be jammed onto the ring gear. If it is a Kohler engine, the starter gear is designed to slip and might make the sound you are referring to.
[Reply]  [No Email]
Carlyle Hoffman
04-14-2014 08:20:31
74.79.134.247
Sounds like it is SETTING up?????
[Reply]  [No Email]
El Toro
04-14-2014 06:44:02
96.244.7.206
Pull the sparkplugs and see if the engine will turn over. Hal
[Reply]  [No Email]
Bob
04-14-2014 08:37:53
64.255.159.192
 Re: JD 400 in reply to El Toro, 04-14-2014 06:44:02
AS Toro said, see if it's locked up. Once sparkplugs are out it should be fairly easy to turn over buy the crankshaft PTO pulley behind the grille.
Something to check... "crosses" in the engine-to-hydro driveshafts are known to wear out/fall apart/trash themselves. Something MAY have fallen apart there.
If the engine is free and he driveshaft is OK, pulling the engine to get at the starter is NOT as bad as you may think.
Just LOTS of little details!
[Reply]  [No Email]
Dennis (VA)
04-14-2014 08:48:41
70.208.161.6
 Re: JD 400 in reply to Bob, 04-14-2014 08:37:53
Sorry. but I don't understand crossings. No one has ever said mom raised a smart one LOL
[Reply]  [No Email]
Bob
04-14-2014 10:45:52
64.255.159.192
 Re: JD 400 in reply to Dennis (VA), 04-14-2014 08:48:41
[Reply]  [No Email]
Dennis (VA)
04-15-2014 06:42:47
70.208.158.219
 Re: JD 400 in reply to Bob, 04-14-2014 10:45:52
Bob, Thanks for the drawing. Will drag machine into barn tomorrow (cold hereand go through the suggestions.
Thanks
Dennis
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
