brandon j
I cant find a hidrolic oil filter for the tractor does any one know where i can get one and if not what did you do to replace it?
Thanks Brandon
Do you have the old one?
Napa and Autozone have Cross reference capabilities. Enter the numbers from the old one and it should be able to find a replacement.
I take it yours has the filter with the line fittings built in? If so, it is a New Holland part and is pricey. They can be converted to a spin on if you get the parts from a tractor with a spin on filter, the late closed side tractors have spin on. If you go back with the original style, make sure you put it on the same way it was, it has a built in check valve and will blow stuff out if put in wrong.
I used a Fram PH-16 which cross references to a whole bunch of filters including Lee"s Purolator.
Here"s a Cross Reference chart for the PH-16.
http://www.framcatalog.com/PartDetail.aspx?b=F&pn=PH16
BTW, The original Ford Part number is either JAC-130355 or JAC-130555. These are Jacobsen part numbers as these tractors were built by them.
