TractorLinks.com
Re: Plowing a little garden
El Toro
04-12-2014 10:26:11
The plow is off an old Viking walk behind tractor I bought in 1960 for $15.00. When I sold the Viking I kept the plow. I had to make that frame
for the plow so I could use the sleeve hitch. Hal
rrobert
04-12-2014 11:45:08
 Re: Plowing a little garden in reply to El Toro, 04-12-2014 10:26:11
Oh great! My brother in law has same tractor and has asked me about adding implements for it.
I don't see how but if you did it, then it has to be possible. But, he wants to plow the whole front 2 acres of his yard!
El Toro
04-12-2014 17:05:55
 Re: Plowing a little garden in reply to rrobert, 04-12-2014 11:45:08
He needs a Farmall Super C with the fast hitch. Also get the two bottom fast hitch moldboard plow.
I had one back in the 1970's. I could plow a big garden quickly. Here's some of the items I made for my Wards tractor with the sleeve hitch. I made an H hitch so I could tow my lawn trailer and log splitter when needed by rotating the H hitch 180 that used the ball hitch.
The frame used for the plow was made like the hitch on the Viking. I made templates of the handles. The hardest part was bending them alike.
The cross piece near the rear is used to support the plow. The tractor had it on the handles and it was used so you could steer it, also the cultivator attachment had rollers that moved on that cross piece when steering. Hal
PS: The lever on the plow sets the point depth by tilting the point. A piece of 1/4" flat stock steel that was bent and welded. The lever is bolted on using two 1/2 cap screws.
