Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Gravely 424 crankshaft removal
424
04-04-2014 10:05:58
Bret, I want to believe you but sure don't see a key way (similiar to the flywheel end of the shaft). I took a picture but don't know how to include it in the reply.
El Toro
04-04-2014 10:10:40
 Re: Gravely 424 crankshaft removal in reply to 424, 04-04-2014 10:05:58
Here are the instructions for posting picture using the Advanced Posting Tools. You also need the pictures on My Documents or Pictures since APT will take you there when click on " Browse". Hal
424
04-04-2014 10:39:04
 Re: Gravely 424 crankshaft removal in reply to El Toro, 04-04-2014 10:10:40
Here is a poor pix of the PTO end of the crank.
El Toro
04-06-2014 06:58:41
 Re: Gravely 424 crankshaft removal in reply to 424, 04-04-2014 10:39:04
Use a split bearing separator behind the gears and pull on it. Hal
t1
04-05-2014 07:31:18
The gears are put on HOT, and then when they cool they lock into position. A good puller usually can pull them off, but you may have to heat them with a torch if they are stubborn. don"t heat the shaft, just the gears.
Depending on its age, it might be a 2 piece gear, or a single gear. I"d use a bearing puller or something behind the gears so your puller jaws aren"t pulling on the gear teeth (they break).
IF you go here, you will find gravely manuals that will show you how to do all this stuff.
http://gravelytractorclub.org/
rrobert
04-04-2014 11:46:35
What engine? The best thing to do is find a diagram of the engine.
Maybe wait for a reply from someone that does know what the engine looks like inside before trying anything below.
I think you are right. Those do look pressed on. There might be a C clip inside the engine. Those gears might be a seperate shaft from the crankshaft similar to a camshaft.
I am not sure what that engine looks like inside. I would pull the 4 bolts on that plate and see what is on the other side. Don't be too rough with it, I don't want you to break anything expensive!
