need help w/ parts for Ford yt16h
I"m trying to get this 1991 Ford YT16H running. It was my wifes late fathers. I have already it running, but the fuel leaks out of the nipple that the fuel line connects to the tank with. The rubber grommet that holds the nipple into the tank wall seems worn. I would like a part number so I can order a new one. When I look at a parts diagram I can find that particular part. I would appreciate any help. Thanks.
The yt16 ford,new holland & lawnboy tractors were built by gilson which is now owned by toro,check local yellow pgs for a lawnboy dealer,toro also owns lawnboy & supports gilson thru their lawnboy dealers,if going to a lawnboy dealer use 52140(91)for tractor mod#,online parts diagrams for ford,new holland & lawnboy tractors only show tank,fuel gauge,fuel hose & clamps and no breakdown on tank nipple fitting,lawnboy dealer may have a breakdown on nipple assembly for tank or know of a replacement for same.
I have a Ford LGT (LGT100)---discovered some time ago a website on Yahoo called something like Ford/Jacobsen lawn-garden tractor forum. I"ve lost track of the site--but remember there were all kinds of Ford "experts" and a fellow who sold a DVD with the parts breakdown for all models of the Ford Lawn/Garden models inclued the
YT versions. Hope this helps.
I am thinking that should be a common part. We have them aftermarket at the dealer where I work. I would just call around to some lawnmower shops and ask for a Fuel Tank Grommet or a Fuel Tank Outlet Bushing, they should be able to fix you up.
No one had a part #, but one place says it's a universal part. I bought the grommet $2.35 and it worked great. Thanks for the suggestions.
Google "Landscape Power" Its a parts website. That"s where I found parts for my 1994 YT16. They have diagrams and everything.
Just for the record, I do believe in supporting local small business. My local mower repair shop was not able to help me with some of the parts. They did however make up the chain drive portion of my transmission for cheaper than I ever could have bought it online.
