Bigger oil filter on Intek twin?
johnlobb
My 2001 22hp Intek on my Troybilt garden tractor takes either a B & S oil filter 492932S or a John Deere 125424. They are quite small, and I wonder if anyone has found a larger auto filter with the same base and threads that will fit? On my Saturn, I have found a larger filter that I put on.
B&S makes a small and large filters for their engines. The one I use on my 20 HP Briggs is a NAPA gold 348.
In the back of NAPA's master filter catalog, are
Specs for ALL of their filters. It has height,
width, thickness, diameter, THREAD SIZE,gasket
inside and outside diameters, and gasket thickness
You can find a filter with the same (Spin-on)
threads and gasket size, and cross reference to
different lengths, etc.
I guess "bigger" was a poor choice of words. I should have said "longer", it could be up to twice as long and still fit. Obviously, the base and female thread would have to be the same as the OEM filter.
I have both a 20 horse kolohr and a 17 horse tecompsee. I have been running fram 3614 oil filters for a dodge neon for a couple years with good luck. a lot cheaper too.
