JOHN in PENNSYLVANIA
I have a 1974 Cub Cadet model 129. The tractor runs beautifully. And drives beautifully. But I have one issue that I want to know if It can be corrected. That issue is, when I push the lever forward to move the tractor faster and the tractor is at the set speed everything is fine... However, the tractor seems to move the lever itself into the fastest possible position going forward. It"s done this many times. I have tightened the friction nut on the shaft to try to prevent this but the transmission still lunges forward to the fastest possible position any suggestions
