Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Removing snowblower wheel
joe csuti
03-06-2014 03:21:52
I think I see your problem now taking a closer look at traction drive assembly drawing/parts list.
Right side frame is slotted & allows shaft assembly to drop out of frame after bearing bolts removed,however it appears there is a clearance hole in left frame that axle passes thru & into left bearing on outside of frame,check axle,on inboard side of each bearing you'll probably find a thrust washer & roll pin thru shaft to hold axle in position preventing it from moving left/right when useing blower,remove right roll pin from shaft,clean up end of left side axle & try to drive axle out of rim,with pins in axle same won't move when pounding on left side of axle,with right pin out axle will slide thru right bearing & left wheel hub will work against left bearing when pounding on left side of axle.
