Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Removing snowblower wheel
joe csuti
03-05-2014 17:33:34
The only thing holding wheels to shaft is a lynch pin thru rim hub & axle on the outboard side of each wheel,if you have removed pin(s) and rim won't come off it's probably seized to axle due to rust.
For a quicker solution for rim removal,remove drive chain from sprocket on axle,remove 4 bolts holding the 2 wheel bearings to frame & drop axle out as an assembly,clean up end of shaft as best you can then try to drive shaft out of rim hub or take to a machine shop & have them use a hyd press to press shaft out of rim,if your lucky rim won't be bent/damaged.
joe csuti
03-05-2014 17:50:36
 Re: Removing snowblower wheel in reply to joe csuti, 03-05-2014 17:33:34
Another thing you could try before removing axle is put right wheel back on blower with lynch pin,start blower & put in gear & see if you can spin axle in left rim to break free with wt of blower on axle/rim.
