Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: ignition
old
03-01-2014 19:28:06
To much rust on the flywheel will cause that as will spacing of the mag from the flywheel being to great
Bob
03-02-2014 14:23:00
 Re: ignition in reply to old, 03-01-2014 19:28:06
Yes. Some surface rust doesn't hurt anything, rust only becomes a problem when it gets this enough to bridge the air gap between the magnets on the flywheel and the coil.
LOTS of good info at the BRIGGS link below:
ken house
03-02-2014 12:59:27
what do you use to gauge the space?
book match cover?
old
03-02-2014 13:05:51
 Re: ignition in reply to ken house, 03-02-2014 12:59:27
I use the plastic from a soda bottle as a gauge when I do them. Dr. Pepper to be exact LOL
IH2444
03-02-2014 17:34:55
 Re: ignition in reply to old, 03-02-2014 13:05:51
I use a manila folder strip
ken house
03-02-2014 13:11:47
good choice . thanks
old
03-02-2014 13:16:16
 Re: ignition in reply to ken house, 03-02-2014 13:11:47
That said any good lawn mower shop will have the plastic gauge that they would be likely to give you since most mags come with that gauge in the box
ken house
03-01-2014 19:32:19
thanks
old
03-01-2014 19:36:54
 Re: ignition in reply to ken house, 03-01-2014 19:32:19
Also since I have had this happen the wire going to the throttle shut off if the shut off is messed up will cause odd problems like that. To check that I pull the wire from the little clip and try it
