The tractor was running fine, just using oil.
I did a ring and valve job and when I fired it up it ran like singer sewing machine. After running for about 2-minutes, it died. You can let it sit for a few minutes it will fire up and run great for a minute or two and will die again. I have overhauled the carburetor and set the timing with a timing light.
Could the problem be in the condenser or coil? I had a Ford 8N that had the same problem. I changed out the coil and condenser and fixed the problem.
Thanks, JB 9959
Thanks, JB 9959
