Yesterday's Tractor Co.
Shop Now View Cart
Re: Kohler Command 25 add more power
joe csuti
01-05-2014 03:51:20
Depending on what class you intend to run tractor in eng/tractor must be basically stock,in all classes except E(modifed stock)in all classes you can add a max of a 1/2" spacer between carb/block & have a posi/locked axle rear if oem by tractor mfg.In all classes fuel must be pumped gas,no additives or alcohol,the term pumped gas is a broad term,and doesn't define if gas can be hi-test or aviation gas as these are also pumped fuels although either/both may damage eng,this may be a gray area & have to be explored.
In E class-modifed stock you can do internal work to stock block and are probably only limited by the $$ you want to spend for modifications.
If you don't have a copy of rules,do a google search for pulling tractor rules,scroll down to 2013 garden tractor pulling rules & download/save rules.
