Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Kohler Command 25 add more power
Farmall Bob
01-04-2014 11:48:04
Hi Blake,
25hp is a lot of power for most anything around the back yard, and small farm. If you need more power you are going to spend lots of money. Turbo chargers don't come cheap, and then also you probably would have to have an engineer figure out which one would be best for your application. Also if it is for the around the yard it won't make much cents because weight ratio. It would be better to go with a bigger heaver tractor unless you are intending to pull at a tractor pulling event. Bob
Blake03
01-04-2014 12:24:24
 Re: Kohler Command 25 add more power in reply to Farmall Bob, 01-04-2014 11:48:04
The motor is to be used on a pulling tractor and need to be naturally asperated.
Diydave
01-04-2014 16:59:56
 Re: Kohler Command 25 add more power in reply to Blake03, 01-04-2014 12:24:24
You are probably limited to porting, polishing manifolds, and some carb work, if you can find an older carb, with adjustable mixture screws.
