TractorLinks.com
Re: looking for advice
gtractorfan
01-03-2014 19:40:56
Today I had a similar problem with a 9 hp Suburau, only in its second season from Small Engine Warehouse. It was going along fine then just died, never did that before. I hadn't had the gas tank full and suspected moisture. Took it inside, ran the kerosene torpedo heater and got it good and warm. It would run for a little bit and die, just like it wasn't getting enough gas. On those engines the fuel line is buried, hard to get to. I wasn't anxious to tear into the carb. Then I got a dumb sounding idea. (it's only stupid if it doesn't work) My guess was there was a little dirt blocking the gas flow- and if I could pressurize the gas tank it might help. Not having a way to use the compressor I tried a trick I've done with an old chainsaw. With the gas cap off and the tank not quite full I took a deep breath and put my mouth over the fill neck and put as much pressure as I could on the tank for a few seconds. Amazing-- it must have cleared away whatever was blocking the flow, after that the engine ran fine, used it for about 45 minutes with no more problem.
