Yesterday's Tractor Co.
Shop Now View Cart
Re: Got a Briggs question
01-02-2014 06:40:36
This can be caused by a too lean of mixture. When everything else fails to correct you can try to richen the mixture. Since this is probably a fixed jet in the carb, you will need to enlarge the jet by using a jet drill. First determine the jet size by passing the jet drill bits thru the jet. When you find the correct fit, use the next largest and drill out. Of course you can't go back once it is drilled!
