Craftsman snowblower
Lance Pence
New User
Looking for some information,
Have a Craftsman GTV16 that I am trying to match a Craftsman snow blower to. The only v-pulley I see to use is on an angle. Could use any info at all on this subject.
Thanks
please give a better description of the problem. We will gladly give advice if we can understand the problem. By: Rusty Jones (rustyj14)
I have this older GTV16 and I tried to match a craftsman snow blower to it. The blower has a vertical pulley. Looking for a pulley under tractor to connect belt. The angle pulley I was using underneath was not working, making belt jump off. I attached another pulley next to this angle pulley because it was the only one that was semi lined up with the blower pulley.
Hopefully I explained my problem ok, it's kind of a headache to get this to run.
Thanks for an help
Hi Lance, I'm to totally familiar with your tractor model does it have the side shaft engine and if so I don't think that model used an under the belly mule drive I'm thinking it would be like my ST16 where the belt goes from the engine to the SB with a clutching set up between the engine and SB. You may get more information on the Sears section of My Tractor Forum lots of Sears guys very active site.
GB in MN
