TractorLinks.com
Re: looking for advice
MNGB
01-01-2014 14:29:31
Hi gochargers, if the reg gas you buy has 10% ethanol there is no need for heet, and the gas should not drip out of the tank it should run at a good full stream. it it isn't moisture or some blockage in the gas hose then the carb may need a good cleaning.
GB in MN
gochargers
01-01-2014 17:55:09
 Re: looking for advice in reply to MNGB, 01-01-2014 14:29:31
I'm always very careful not to get gasohol in my mowers or motorcycle. Some one told me it was hard on the rubber parts in the small motor carbs. Right or not - that's my protocol
gochargers
01-01-2014 17:52:05
Nothing much worked today so I'll find a heated shop some where, I'll remove the tank and clean it and dry it. Hopefully the carb wont have to come off ----- but I'm not holding out much hope
gochargers
01-04-2014 09:35:34
 Re: looking for advice in reply to gochargers, 01-01-2014 17:52:05
I think I got it. Complete drain and rinse of the tank - dropped bowl off carb and cleaned - ran a copper wire thru main jet "ports" and reassembled. It ran 10 minutes til it ran out of the little bit of gas that was in the tank, so I refilled the tank. It ran 15 more minutes under a lite load and didn't miss a beat
