Farmall Bob
OK, I used my Gravely Tractor with the snow thrower to clear my drive way. But if you remember I was having problems. The carburetor wasn't working right, and also had trouble with the high/low range. The carburetor was leaking, and placed a plastic container under to catch the leaking gas. Noticed the next day there was ice in the bottom of the plastic container. Went to Wal-Mart as they have a large selection of products to choose from. Ended up buying Lucas Oil Product Safeguard. It's a Ethanol fuel conditioner with stabilizers. Placed a cap full into gas tank, and waited a day. Took the tire off to tinker with the high/low range as it wouldn't stay in low range. Made it worse by placing a spring onto that shaft. Should have listen to you guys and tighten by up the linkage like you said. I had fiddled with it in the fall and thought it was all set. Nope! As I may have mentioned before I am not the sharpest tack in the box. It works great. Thank you.
Bob
Bob
