Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Got a Briggs question
Diydave
12-30-2013 16:31:06
Update: Cleaned the carb, fuel bowl had a shadow of gunk on it, no evidence of gelled gas, needle valve clean, I shot gum cutter all over it (didn't pull carb, just bowl) no leaks, re-assembled, runs the same, up and down, like a intake leak, but when spraying gum cutter, around carb, no speed changes, so my guess is problem is elsewhere. ANy fresh Ideas?
t.r.k.
12-31-2013 09:02:09
 Re: Got a Briggs question in reply to Diydave, 12-30-2013 16:31:06
190 is not the model number, so I don't know which engine you have.
If I had one that was doing what you say yours is doing after I was certain the carburetor was clean, I would check the intake tube. I am assuming your engine is a flat-head Briggs. Some times the plastic pickup tubes crack or the gasket gets a split in it where it bolts to the block.
Copyright © 1997-2015 Yesterday's Tractor Co.
