Yesterday's Tractor Co. New Parts for Old Tractors
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Got a Briggs question
Diydave
12-30-2013 04:16:17
96.244.155.184
Got a 190 briggs electric start on a toro personal pace lawnmower. Problem is that it would die, about 10 seconds after starting. Did that 2 or 3 times, then started running, though it seems to not be revving up all the way and it kinda wanders up and down in rpm. Any suggestions? I put a plug in it, old one didn't appear to be in all that tight. By the way, this thing looks almost new, low hours, likely been sitting for a while. Gonna try tinkering with it today.
[Reply]   [No Email]
DelMN
01-02-2014 06:40:36
74.44.209.93
 Re: Got a Briggs question in reply to Diydave, 12-30-2013 04:16:17
This can be caused by a too lean of mixture. When everything else fails to correct you can try to richen the mixture. Since this is probably a fixed jet in the carb, you will need to enlarge the jet by using a jet drill. First determine the jet size by passing the jet drill bits thru the jet. When you find the correct fit, use the next largest and drill out. Of course you can't go back once it is drilled!
[Reply]  [No Email]
Diydave
12-31-2013 17:08:36
96.244.155.184
190cc, I think, It's the 4-5 HP range, vert crank on a toro personal pace 22" mower. I had a finger on the throttle linkage, moves freely, at least against the spring that heads toward the front of the mower. It's not a real bad surge problem, you can just barely see the linkage move fore and back. Methinks I need to do a little clean-up, and see whether it has a air governor, and whether it is blocked.
[Reply]  [No Email]
Bret4207
12-31-2013 16:19:10
64.19.90.196
You can lubes the governors linkages and make sure everything is free. Any chance someone was int here ahead of you and relocated a srping or something?
[Reply]  [No Email]
504
12-30-2013 19:33:13
199.127.54.155
Sea Foam and run it hard.
[Reply]  [No Email]
Diydave
12-30-2013 16:31:06
96.244.155.184
Update: Cleaned the carb, fuel bowl had a shadow of gunk on it, no evidence of gelled gas, needle valve clean, I shot gum cutter all over it (didn't pull carb, just bowl) no leaks, re-assembled, runs the same, up and down, like a intake leak, but when spraying gum cutter, around carb, no speed changes, so my guess is problem is elsewhere. ANy fresh Ideas?
[Reply]  [No Email]
t.r.k.
12-31-2013 09:02:09
24.74.85.78
 Re: Got a Briggs question in reply to Diydave, 12-30-2013 16:31:06
190 is not the model number, so I don't know which engine you have.
If I had one that was doing what you say yours is doing after I was certain the carburetor was clean, I would check the intake tube. I am assuming your engine is a flat-head Briggs. Some times the plastic pickup tubes crack or the gasket gets a split in it where it bolts to the block.
[Reply]  [No Email]
VernMI
12-30-2013 06:20:25
209.86.226.11
Governor is probably caked in dirt and not moving freely.
[Reply]  [No Email]
Diydave
12-31-2013 04:15:05
96.244.155.184
 Re: Got a Briggs question in reply to VernMI, 12-30-2013 06:20:25
Vern, Is it an air governor, or is it internal?
[Reply]  [No Email]
Bret4207
12-30-2013 05:27:58
64.19.90.196
Probably the carbs gunked up. You can try a bottle of carb cleaner, it might help. Chances are it's going to have to be taken apart and at least cleaned if not rebuilt or maybe even replaced.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
