TractorLinks.com
Re: 18 hp briggs intek cam problem?
DelMN
12-16-2013 08:09:34
My guess is that it is the decompression mechanism on the cam. This is usually a spring loaded device that has weights on it and it functions somewhat like a governor does. It holds the exhaust valve open at cranking speed and when the engine is running the weights spread out and shut down the compression relief. The cam is probably good but the spring has either broken or has come off the mounting posts. It is not too big of a deal to dis-assemble to get at it. Side cover, valve cover, back off the rockers to relieve tension on the valves. Then you can slide the cam out and check.
