Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 1970 14 hp kohler no spark
wayne huber
11-27-2013 20:18:09
unplugged the wire at the ignition switch to make sure my switch was not bad. and I did check the plug wire its good . I have a in line spark tester so I can see it flash when I get spark I have the coil with me so I can check with a few places to see if anyone has a coil tester. thanks again for your feed back!!!!
joe csuti
11-28-2013 03:02:12
 Re: 1970 14 hp kohler no spark in reply to wayne huber, 11-27-2013 20:18:09
Disconnect kill lead wire at junction of trigger module/coil also & check between each end of same with an ohmmeter unless you can see length of wire completely between eng connection/ign sw,wire may be grounded due to yrs of heat,vibration & rubbing against sheetmetal or brackets on tractor,if wire grounded it will give same result as turning ign sw to off/stop position even though kill lead disconnected from ign sw.
