855 electrical problem
super 77
New User
I have a 855 the other day went to start the tractor it cranked for a bit then nothing no lights no starter nothing it almost like its a fusible link is their such a thing in this tractor I check the other fuses they seem fine
Check the specific gravity of each battery cell using a hydrometer. You may have a weak battery cell. Should see readings around 1.275 on a fully charged battery. Also clean all connections until shiny including where your battery is grounded. Hal
If this is a jd 855,check battery condition/cables as Hal said,also carefully check that battery cable connection on starter sol is clean/tight as this is the common junction for all +12v in tractor wiring,there is a fuseable link in line from starter battery terminal to battery terminal on ign sw & also a fuseable link in line from sol battery terminal to fuse block.
Due to fact you lost everything I would suspect you have a weak/bad battery,dirty/loose cable connections for +/- battery cables or one of the cables bad.
If battery not the problem,check between chassis/eng block with a voltmeter/12v test light to battery terminal on starter sol,battery term on ign sw & main feed side of fuse block,you should get a +12v reading/light at all three of these points with ign sw on off/stop position,if no voltage reading at any of these points disconnect battery cables from battery & check cables with an ohmmeter,one of the cables may be bad.
If you get a voltage reading/light at sol battery terminal but can only get a voltage reading/light at ign sw or fuse block but not both at the same time one of your fuseable links is bad.
When you post questions include mfg of tractor along with model as wheelhorse also made an 855 in the 60's.
thank you I will try that it's been cold here so I wanted an idea were to look before I start to work on it
IF you need a wiring diag for tractor do a google search for john deere 855 tractor+wiring diagram,scroll down thru links,click on link to "I have a john deere 855 @ pearl.com"dated nov/04/13,read replies,in one of the replies there are links to two wiring diag for 855 depending on pn of wiring harness used on tractor,I didn't check actual differences between each pn harness,however both show fuseible links connected to starter sol battery terminal feeding ign sw & fuse block.
