TractorLinks.com
Re: Gravely walk behind
Farmall Bob
11-22-2013 04:01:27
Hi Jeff,
I have an oil pressure gauge, and the indicator needle goes all the way up. Also I have two rotary plows, they work great. Also have a bush hog mower.
The oil filter is a PH-43 I will try that smaller one you mentioned. Thanks.
Bob
Bret4207
11-22-2013 04:08:06
 Re: Gravely walk behind in reply to Farmall Bob, 11-22-2013 04:01:27
On the rotary plow, don't forget to check the oil level. I have 2 I think and one is in need of new bearings because PO didn't add oil. They made a rotary cultivator you'll often see advertised as a "tiller" that bolt to the rotary plow case. Wonderful tool for cultivation if you have the room.
At one time I had 13 running Gravely L's and boxes and barrels of parts. Renter got rid of a lot of stuff on me that can not be replaced. Had a few dozen implements. The day I found out he'd junked it was a dark and angry day for me.
Farmall Bob
11-22-2013 04:36:25
 Re: Gravely walk behind in reply to Bret4207, 11-22-2013 04:08:06
Bret,
I am sorry to hear about your loss. These things are priceless! Will he pay for the loss? I have these (4) and work on them for winter projects, thinking that if country goes to hell someone may need one for gardening.
ob
Bret4207
11-22-2013 13:30:19
 Re: Gravely walk behind in reply to Farmall Bob, 11-22-2013 04:36:25
Pay for it? Right! Naw, that was close to 20 years back now. I think your right about things headed down hill though. BCS makes a good modern version but it's expe$$$$ive. There were some guys trying to fit a low speed diesel to an L model frame. No matter what they try it's still too fast running. That's the problem with the Kohler powered ones like Jeff mentioned above. I ahve one and it's find for mowing the lawn with a finish mower, but it's way too fast for the plow, the sickle bar, the bush hog, the old snowblowers, etc. I think those Gravely engines ran about 400 rpm wide open. Nothing else comes close.
