TractorLinks.com
Re: Gravely walk behind
Farmall Bob
11-17-2013 02:58:57
Bret,
OK, some day I will do just that, but right now I have (4) that are not working. They are all newer models, 1964, 1966, 1967, 1968, there was only (1) running. I had it in the community garden bush hogging tough grass and corn stocks, then raking out all the stubble, then roary plowing it. Got bad bug problems! Gravely lasted until I was done for the day, then quite as it was smoking pretty bad and fouled the plug. Thank you for the information Bret.
Bob
Bret4207
11-17-2013 05:48:44
 Re: Gravely walk behind in reply to Farmall Bob, 11-17-2013 02:58:57
Bob, when you work them hard you have to maintain them well. Make sure the fan belt is tight enough to be turning well, I've seen them slip. Make sure the air baffles are all there and that the fins and passages are fee of dirt and debris. An air cooled engine working hard needs air flow to cool it. Don't lean the tractor out too much and if you have an oil filter keep it changed, keep the oil topped off and in warmer weather or when working it hard use straight high quality 30 weight. You also want to make sure the timing is on, too much advance will kill them. They will pass a little oil when working hard, mostly form old gaskets, but the oil fill cap up front will vent oil vapor when she's bulling.
They are great old machines and you don't need to run them flat out to make power with that long stroke, low speed engine.
