Yesterday's Tractor Co.
Shop Now View Cart
Re: 22 hp B S Intek info needed
joe csuti
11-15-2013 03:32:05
When eng cold & before starting check that valve cover gasket(s) not leaking & dripping on muffler causeing smoke till muffler gets hot,after that pull dipstick & check for an overfull oil level,smell oil on stick,if you smell gas in oil remove air filter & check for oil in filter/filter houseing,all the above are indications of a problem in carb possibly caused by a leaking float valve,sticking float or some other problem in carb,if valve leaking/float sticking gas will drain into crankcase when eng at rest,this will dilute oil/raise oil level,when eng started excess gas/oil mixture in crankcase will be blown out breather valve & into carb causeing smoke,this is a common problem on many mod ohv briggs eng.
Other possible causes of problem-as has been said wrong/too thin oil,worn valve guides/bad stem seals,ring/cyl wear & oil leaking past rings when eng cold & at rest,sticking rings,broken ring(s)head gasket(s) starting to leak when eng cold.
Get mod/type numbers off eng & goto link below,in briggs eng parts listings lookup your eng mod/type#,look at assembly drawing of head & see if there is a seal for/on valve stem listed.
