Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 5 hp briggs
ShadetreeRet
11-08-2013 22:32:10
I have never seen,nor do I believe you will find a compression release on the intake valve. This would cause blow-back or backfire through the carburetor, which can not only cause problems but is dangerous. If you have ever seen an engine blow fire back through the carburetor, you will know what I mean. The compression release lets the compression escape through the exhaust valve.
George Marsh
11-09-2013 00:55:41
 Re: 5 hp briggs in reply to ShadetreeRet, 11-08-2013 22:32:10
ShadetreeRet That's what I thought until I lost the cam on an 18 hp briggs. Decompression release was on the intake, yes intake. My 13 hp honda the decompression release in on the exhaust.
My 5 hp was blowing gas out the carb at least 8 inches, yet no back firing even though the engine was running extremely rich. That means the intake had to be closed when engine was firing on the power stroke while the intake was open during the compression stroke causing blow back through the carb. Sounds to me like there is decompression happening on the intake valve. I'll do some research on the engine. George
ShadetreeRet
11-09-2013 07:14:44
 Re: 5 hp briggs in reply to George Marsh, 11-09-2013 00:55:41
George, I stand corrected. I will admit that I am not up to date on the newer engines, but to me it doesn't make sense to put the compression release on the intake. I guess some, just out of engineering school pencil pusher, decided he knew better. Go figure.
